Hi all, I have a 1980 85hp Evinrude v4 that takes multiple starts before it will continue running. It starts up easily, but then stalls out as though it's starved for gas. After multiple starts (like 20), it catches and runs great at idle and at all speeds—smooth, no hiccups. This spring I removed and cleaned the carbs and replaced needle and float, replaced fuel pump, lines and clamps (no leaks). I have good pressure in the line from the tank—no leaks in feed line. Where should I look first for the cause of this cold-start problem?
