I forgot exact model but it’s 1980s 25hp between model# 5705532 - 6416712 since part# are the same Anyways I can’t get it to stay running I can get it to start with choke on and will run if I keep giving it gas /w choke on but then just dies once I turn off choke , I rebuilt the carb with kit, and also tried a 20hp carb I bought offline that fit it but it does the exact same thing. I replaced plugs/coils/wires I have no idea what else to check
Also
i replaced my water pump I have it set on key shaft correctly and new seals but it will not pump any water just steam I blew air through lines and can’t find any clogs, I am using a 55 gallon drum of water. Does the water level need to be level with the water pump to work or just cover the water inlet on bottom?? Thanks for any help
Also
