1980 25 Evinrude
seabob
Motor has a steady stream of water out of tell tale hole after warms up stream starts sputtering and gets hotter, removed lower unit connected water hose to the copper tube eliminating water pump, does same thing would head gasket cause this thanks or good guess
compression has dropped a little from 120+ to 110s top cyl 5 lbs less probably pull head off today may possibly be able to tell thanks
