"The idle arm..... Some have a
"The idle arm..... Some have a adjustment whereas it can be limited, others do not. The ones that do not.... don't extend it to a degree whereas the engine races away.
No need to open the control box. Both cables on that model would be the same length. Simply observe the cables at the engine end move the throttle/shift lever somewhat. The cable that moves first is the shift cable.
A V6 engine with with fouled carburetors, running on 4 cylinders, more or less, will rev quite high in neutral as no back pressure exists. You mention 7k...... you do not want to exceed 1500, 1800 rpm in neutral. To do so is inviting a runaway engine, and before you had a chance to shut it down, connecting rods would be flying out the sides of the crankcase.
Clean the carburetors."
