My 15hp manual start is having starting issues. As of the end of October, it ran well during a trip and did so for the 4 months of weekly use before that. In June, it was not running but I found a tear in a fuel line and after replacing it the motor ran okay. Once initially started, it would start every pull thereafter after shutting it off. On the initial startup, it would take 10-20 pulls to get a spark. Now, it will not catch. I checked the fuel tank, primer bulb, and line, all were working correctly. The motor has not run in a month, and I forgot to run it out of gas as i usually would. I would guess a clogged carb, or bad spark plug, but I'm unsure.
