Johnnyrude
hi,thanks in advance for the help want to test charging system componets stator coil,rectifier.engine has be sitting a long while and working to get operational but not sure of the voltage/ohms readings.the coil has a hot spot/burned area have located used but want to ohm out rectifier and used coil (under flywheel coil) befor purchase.thanks
