spearedfishes
Hello Everyone, I am new to the Forum but have read some good stuff. I have a 1980 115hp V4 VRO 2 stroke with 500 hours. The VRO has been by passed so I mix the 50:1. I bought the boat and motor from 3rd owner. Boat sat for 3 years, and she stared up but died after 30 sec, no excessive smoke sounded good. Compression test after using some marvel in upper cylinders for a day is 115 to 120 on all 4. I tried to get engine to run with the sea foam spray trick in carbs(used this trick on many Motorcycles). Boat would run for about 3-5 min and then die. Tried it 4 or 5 times the decided to rebuild the carbs. Fuel bulb would hold pressure before carb rebuild. I rebuilt carbs with a Johnson carb kit (replaced every thing I could with kit), replaced fuel filter(old fuel filter was gunked up), new plugs and now the engine has a lot of white smoke especially out of prop area. Engine idles funny but when you turn up RMP over 2k she sounds good. She drinks a lot of gas (drinks about 3 gallons a little above idle a hour) and the fuel bulb wont stay hard, if I keep pressing fuel comes out of carb, but she will run until the tank is empty. I do have to start with high idle to get her going. She pees well. I'm using a small 3 gallon tank to trouble shoot and bulb holds pressure until connected to motor. Cant find fuel leaks on outboard and lines look good. Any help would be much appreciated.
