My 70 hp mercury will start and idle up and down on muffs but in the water it boggs down and shuts off. We found the # 2 coil is either bad and/or the wire to be bad. Would it start and run with the # 2 cyl not working? And could that be the issue it is having trying to run in the water? Curiously also we can start and idle on muffs with the # 2 plug wire hooked up or not????? Does that make sense to anyone????
