Ignition points system
I am unable to set the intial timing - distributor was just rebuilt
I put #1 cylinder at TDC on the compression stroke
Dropped the distributor in and married it up with the oil pump drive shaft
Positioned the points to where they are just beginning to open
Problem is the rotor points in between two posts
I have spent hours trying to get it right- namely the position of the oil pump drive shaft female end and the distributor male tang end
Nothing works - the rotor always points to in between two posts.
Am l doing this the right way and or is the engine timing out of spec
Again thank you for any help
