M Islander
I have a 1979 Catalina 350 with Marine power 350's. On start up of the starboard motor there is a gush of green coolant then white in the exhaust water and continues to lose collant when running. Motor starts and runs well.
Water pump impeller is fine,all cylinders pressure test well, heat exchanger tubes are clear and the heat exchanger pressure test is good. Would checking the riser,exhaust manifold gaskets be the next step or should I be looking elsewhere?
