Good evening everyone, I have a 100tlr79s Johnson Javelin outboard and took it out for the first time this spring and had issues with it when increasing the throttle. When I got home, took a look at the engine and carbs, and then pulled off the air intake extensions and saw that I had a cracked throttle clevis, plunger to lever (part # 0322405), and this was the reasoning for my engine to bog down and shut off when I tried to take off (Hallelujah, was afraid it was something far worse!). This part is not broken completely, the clevis itself has a side that is broke, so the throttle/choke arm keeps slipping out.
This is my question, the part (0322405) is discontinued and I have scoured the net looking for a replacement (Ebay, iBoats, etc), to no avail; what is one to do here? Would it suffice to just fasten some kind of ring (i.e. key ring) to close the eye and keep the throttle arm in or is there another alternative or replacement part that can be used? I really enjoy the ole ranger aztec, with the javelin 100 on it, and have overcome issues in the past, however I would greatly appreciate any thoughts or suggestions on how to proceed.
Thanks again
The New Guy
Dan
Thanks again
The New Guy
Dan
