1979 Johnson 85 HP Timing Issue
Brandon55
So I am new to working on boats so please be patient with me but I have a bit of experience with mechanics and I learn quick.
So I took my spark plugs out and and put my #1 cylinder at tdc but the flywheel marking is 90 degrees off from the point on the engine to line up tdc. And I have just recently learned that it is not like a vehicle where you can just rotate the distributor. So if anyone can explain to me how to adjust the timing I would be very greatful.
Sheared flywheel key???? Wrong flywheel??? I guess you know the uppermost cylinder is #1, next one down (other bank) would be 90 deg later.
