Tatersalat
Hi everyone, I hope someone on here will be able to help me out.
I've recently bought a boat with above outboard and took it out on Loch Lomond, Scotland a few days ago.
It went ok for about an hour and then all of a sudden cut out as if it ran out of fuel.
It started right back up, but kept dying when I put it in gear.
On land, in neutral and in gear, it will rev up fine if you gradually open the throttle. when you quickly open the throttle it dies too.
Today I have fitted, new fuel lines, new fuel line with primer bulb, new spark plugs, new fuel pump and stripped and cleaned all 3 carburettors (I didn't remove the high speed jets, but sprayed carb cleaner and used compressed air to blow them through). Done a compression test 125, 125, 130.
I have run out of options.
Anyone any idea what I can check next?
