I am desperate to get this motor to pee. I have replaced the water pump as well as the thermostat, wich needed to be replaced bad. Put it together and NO PEE. Even took the lower unit into a bucket with a drill and watched the tube from the water pump and saw very little water being pumped.
All the tubes are clear and should pump fine. This motor seems to run good except the water issues. What else might I do. Help it is my dads motor and I really want to get it running as a kicker for my bigger boat.
Thanks,
Craig
Thanks,
Craig
