Started up the motor to see if the starter would engage and when the motor started firing lower unit oil started leaking out the weep hole below the water intake. There was significant water inside the lower unit after draining. About a month earlier I replaced the water pump, and also the seals have never been replaced on the motor from what the seller has told me. What seals would be causing this and could the water pump play role in the leaking?
