ok. I got everything back together. Started and ran fine at home. Took it to river and cranked up fine. Eased out to deep water and after a bit increased throttle. She was smooth but not as much power as it should have. So I started tweeking the lean/rich screw, at about half throttle. Then throttle it back up. Did this 3 or 4 times. Once when I did this after getting to full throttle, she all of a sudden went full bore, and was everything I could hope for. I mean she just took off. After a minute or 2 of straight wide open running and grinning like a cat I let off throttle and she died. Tough to start so I went back to 1 1/4 turns from closed and she fired right up, but no real power like before and no amount of adjusting did any better. Filter is super clean, put all new gas lines, new tank, rebuilt carb. She runs smooth so hard to believe one cyl. is not doing it's thing. Lack of spark etc. Compression good in both. Any ideas?? Trying to figure what changed for that brief time where she ran like new. Fuel pump? pressure in fuel bulb stayed consistent. New gas can and air valve open. Haven't had time to pull plugs but I will, and replace them with oem. I checked them both though when I started working on her and they both threw a good spark.
