fisherman894
1979 johnson(15r79e).first start cold-choke on starts 2 pulls.warms up take choke off,will idle fine all day.go to take off acts like it is running on one cylinder till half throttle-than clears out and runs fine.will acell no problem.compression=105,110.carb rebuilt(had old cork float-had let carb soak in cleaner over night-blew out with comp air).motor will start and run fine in a barrel-no miss.water pump and t stat replaced.have pulled spark plugs when this happens-top cylinder plug wet.bottom cylinder plug dry.have checked fuel pump(removed,insalled bolt and nut on pump,primed bulb-pump tight.link and synch done.top ignition coil replaced.mixture adjusted for best possible idle,and performance.have also done decarb with seafoam.only thing not checked is if i am losing spark(possible cdi black box????)pleas advise this is driving me nuts!!!!!!
