[email protected]
Hello. I am hoping someone could provide me with some insight. I have a 1979 Johnson 150HP V6 150TL79C. I purchased it with a pontoon on 28 Dec 2015. The day I bought it I brought it out on the water. It ran great. I brought it home and started changing things on the boat to fit my likes and dislikes. I ended up rewiring the power lines and replacing the batteries with Marine approved batteries.
I tested the motor about 3 months ago. It started and ran for about 10 minutes and I turned it off. The following weekend a buddy and I took a trip to the lake, but it in the water and I ended up killing the batteries trying to start it. It turned out both Marine batteries I had were dead.
I replaced the batteries under the warranty. This time when I attempted to start it I couldn't get the motor to turn over. I ordered a service manual for the motor and began reading up on the process or repairing it.
I looked at the fuel but didn't appear there was water in it. It would stutter try to turn over, pop some exhaust, etc...
I looked at the Coil Packs and noticed they were cracked really bad and looked like there was some sort of sticky liquid coming out of them. I read many different forums that said they may be repaired if not too bad but it was best to replace them regardless.
I ordered 6 Sierra 18-5176 replacement coil packs. I removed the original coil packs using the information in the service manual.
After finishing the install I started the engine but it had a different sound to it when starting. There wasn't any exhaust this time either.
I checked the spark plugs with a newly purchased gap tester but the tester kept falling apart on the ground clip and I had to reset the spring every couple of times. I couldn't get it to spark. I ended up doing a resistance test on the coil packs and spark plug wires and all of them registered between 274-280. I didn't see information in my service manual about where the resistance should be.
The thing that confuses me about this is I didn't bother to test the spark prior to changing the coil packs but based on how it is responding I am guessing that I did get power and now the plugs do not.
I tested the resistance on the Power Pack as well and the manual states there should be a higher resistance number on the D ports in the plug and a lower number on A,B, and C ports. When I tested it I got .001 for A,B,C and 1 for D. I wondered if I tested it wrong. I also did not see information in the service manual about where the resistance should be.
I started to wonder if the plugs on the coil pack are not making a connection with the plugs on the Power Pack. I did not use Dielectric Grease. Should I use it on the plugs? Is that safe? I also did not put any on the wires or spark plugs.
Side Note: I did notice a very small fuel leak on my Fuel Pump/Filter. I ordered a gasket kit for it.
Does anyone have any suggestions about what may be the issue or if I am doing something wrong? I was debating on just purchasing some used power packs to test with but didnt want to waste money.
I attached some photos of the coil packs and spark plugs.
