Hello all,
I am working on a boat for a friend. Spent many hours over the winter repairing this and that. Went to start it this weekend and the following happened. When the remote was put in reverse the prop turned CW which is forward (does have a R/H prop) and the engine went to full throttle. When the remote was put in forward, the prop turned CCW and at a very low RPM. I took the linkage apart at both the engine and the remote and everythin appears hooked up correctly, i.e. the forward/reverse cable goes to the forward/reverse lever on both the engine and remote and the throttle cable appears to be on the correct remote lever and engine connection as well. Everything is backwards. Any thoughts?
