Hi all, newbie here to the forum. Tried to do a quick search for answers but didn’t find what I was looking for. I hope you will be able to help me out.
My Father gave me a 1979 Evinrude 4 hp outboard so that we can fish the hp restricted water near our homes. When I picked it up from him he asked I thought it would be an easy task to get it running. The tank smelled varnished but I thought “piece of cake, we’ll be on the water in no time”. That was 2 months ago!!!
Tearing engines apart to rebuild is nothing new to me, but I am not too familiar with outboards so this is what has occurred so far.
Checked for spark and compression. Good spark but no compression. Checked to ensure head wasn’t warped. Replaced head gasket. Pistons look good, but a little bit of side to side play in cylinder. Removed carb tore apart and found it was very clean and had no build up in it. Soaked in carb cleaner for two days, wiped down, blew out all passages and rebuilt with new carb kit. Set float height at level with carb body. Replaced needle and installed until just making contact and backed out 1.5 turns to start. Removed fuel tank from top and filled with carb cleaner. Let soak for 2 days. Emptied and rinsed with 50:1 mix gas. Ensured fuel shut off was working and that fuel was flowing. Replaced fuel lines with high pressure fuel line and replaced in-line fuel filter with clear version. Used marine zip ties where needed. Replaced both plugs with Champion L77JC4 plugs and gapped.030. Filled tank with 50:1 high octane, opened cap valve and proceeded to pull recoil 5 billion times with no success. Try removing cap completely to ensure tank is getting air, no luck. Out comes the ether, fires right up. I figured that it should definitely start now, Pull some more and nothing happens. Spray fuel into carb and runs fine. Pull fuel line, Fuel is getting to the carb but when I pull apart to inspect no fuel in bowl. Recheck all passages, no blockage found. Needle and seat are not binding. All jets clean. Reinstall and nothing but more pulling on recoil and cursing! Tap on carb body to see if needle is sticking, no luck.
Time to drink frosty beverages and figure out why I didn’t bring to professional mechanic from the start and still tell everyone I got it running, but alas I will not be deterred!
Any help would be greatly appreciated! Thanks for your time .
