Model # 25904R
I had it out on the water a few times this year after rebuilding the power head. It ran great.
A couple times it bogged down to almost no power when at full speed. Last time it did it, I was able to drive idle speed back to the landing and shut it off and it doesn't want to start since.
Has new plugs (spark jumps over a half inch gap on both), good compression (both cylinders have same psi) , new fuel pump, rebuilt carb, new lines, tank, bulb, etc.
If fires with starting fluid so it seems as though it's a fuel issue based off my knowledge. I also put a few drops of mixed gas into the spark plugs ports and it fires then. Won't stay running though because seems to not be getting fuel.
At the carb I don't really smell gas, but the bowl is full. I removed the carb Looked through carb port to see reed valves and from what I can see they look ok...
Needless to say I'm stumped. Any well experienced and knowledgeable advice needed please.
