Here is a tough one.... I am about the 3rd owner of this motor (and boat) and I am attempting to install a new impeller assembly. Whoa....whoever owned this motor earlier, used some kind of gasket maker to seal the lower casting to the central castings...
I have removed the 5 bolts necessary to lower the casting, but no wiggle insight. I am desperate for a solution in some kind of solvent that will unseal the lower unit.... IF THERE IS A GASKET MATERIAL USED.
I don't see any external view of anything that resembles material.. so there very well not be anything used.
But I suspect.
If not.. then how do you get this puppy loose so I can finish my impeller installation. ??? Please help.
PrimoDude.
But I suspect.
PrimoDude.
