"With help from everyone at th
"With help from everyone at this site, my engine is running better with only one more problem: Often, when I shift into forward gear, the gears chatter and there is often a sharp "clunk". If I shift with too much power, the boat goes into gear but lurches forward. This is much less evident when I have it hooked up to a hose rather than in the water. I am not shifting slowly but sharply as I should. It does not happen when I shift into reverse. Once in gear, it does not slip out and the engine seems to run fine at high and low speeds. I just put on a new prop because the old one was slipping. By the way, the throttle handle distance forward to engage into forward gear is much greater than the distance of the handle into reverse. Could this be a linkage problem or a clutch dog problem? Thanks for any help!"
