New here, but glad to see a forum that is actually active. I have a '79 55hp evinrude that has an occassional misfire. By occassional I mean that when the throttle is advanced enough to give the small boat some speed the motor starts running very smoothly EXCEPT about every 5-20 seconds it misfires 1 time. The engine sort of goes "BAM", and then it runs perfect for another 5-20 seconds before misfiring again. It goes on constantly regardless if the engine is cold or warm. It certainly seems like a spark problem (replaced the plugs already) that only shows up under higher rpm's. The heavier the load, or the higher the rpm's the more frequent the misfire.
From the manual I have learned that it is a Type II Capacitor Discharge Ignition. I do not know exactly how to troubleshoot this problem as it is difficult to simulate the high rpm's at home.
Any thoughts?
Any thoughts?
