Mikey N.C.
Advanced Contributor
Here's situation. Boat came in shop last week , just started on it this afternoon for about 2 hrs. Boat cobalt 1979 with 260 , 350 cid. Customer replaced head on port side, water pump, fuel pump,exhaust and riser gaskets and new carb. Customer said he needs valves adjusted on port side and timing set and coil replaced. Motor has Mallory distubuter unilite I thank. Has module , had Accell coil 12 volt no external resistor , replaced coil with new Accell coil same type, positive side on old coil nut was stripped. Customer had clipped( cut) brown wire to tach. He said on phone it was getting smoking hot. He said he had motor running. Mallory distubuter has red wire from pos. side of coil and green wire from neg. side of coil and brown wire to ground. Ok adjusted valves on port side. Installed valve cover , marked balancer and tab 8° before. Turned motor over , no start , hooked up ferrat lite. No spark, used grounded type spark tester one #1 spark plug wire no spark. Checked ignition switch have 12.6 with key off and 12.6 key on. It's 3 post ignition switch all have 12.6. Did continuity test on shift interup switch.
It was a closed loop at all times. So took little phillips screw at connection for shift interuped switch. Still no spark . went to coil pos. side key on 5.34 volts. I'm going to look at in the morning. This system I think had a ballast resistor when it still used points, and they were near coil , can't find. I have cdi cheater key switch but only has the two large pins, this motor harness with 3 large pins so can't eliminate boat side harness. Any input would be appreciated. The thing about this boat is boat side harness is routed at top of gunnell and panel runs length of boat , no access. Thanks
