1979 15 hp Johnson Idle Adjustment / Prop Selection
Bandogge
Ok Guys, 2 part question. I have a recently acquired 1979 15 hp Johnson. I've had it on the water a few times and it seems to perform pretty well. I'm pushing a 14" aluminum V-hull with 2 grown men and all the fishing amenities and she's doing at least 20 mph. The RPM's do seem a little low though. I'm running the prop I bought the motor with which is a 9 1/2 x 10.
That leads me to question no.1. Is that a good prop for this application? As I said, I am getting good performance (as far as I'm concerned) RPM's seem a little low but that's not necessarily a bad thing is it?
Question no.2 refers to the pic I posted with this. Why do I have to adjust my idle in past the obvious stopping point? As you can see in the pick, it's adjust to the point where the guide is riding up on the threads. Even though it idles fine in that position, it seems to me the adjustment is a little excessive.
Note: I checked the butterfly and it does close and open all the way when the throttle is worked forward and back.
Thanks in advance, for you're help.
