My boat and motor have been in my family since day 1. It has lived most of its life in northern MN approx 900ft of elevation. In 2008 I moved to WY and brought the boat with me approx 5000ft of elevation. I ran it with the low elevation jets for several years. This spring I rejeted trying to get the performance I had in MN. After rejeting it doesn't seem to do any better. I did a compression test and found 68 - 70 psi on all 6.
The motor is on a 78 lund aluminum. The motor is proped with a 14X17P, max rpm 4500. In MN rpms would run 6000 or higher with the 17P prop used it for waterskiing. Most of the time ran a 19P prop. I am still able to pull my wife up on a wakeboard, but there is no chance of pulling myself up.
Did I mess it up by running the wrong jets?
What should the compression be?
Whats is wrong, I'm guessing my rings are gone.
How hard is it to fix?
Where can I find a better manual than the seloc I have?
Any help would be appreciated.
