"Hoping someone can offer some
"Hoping someone can offer some help quickly as I have someone interested in buying my boat and trying to fix what I thought was a simple slipping prop problem but marked the nose cone and prop hub today and no change after taking it for a run.
Am I right in assuming the nose cone is splined onto the prop shaft and shouldn't also slip if the prop was actually slipping on it's rubber hub?
The nose cone also has the center bolt attaching it to the end of the prop shaft.
Is there some other simple trouble shooting things I should check first that might be out of adjustment that would cause the slightly higher revs when under load. Occassionally it will sound like it just slipped completely out of gear when at top speed and I'll throttle back and throttle back up and it will revert to it's normal slightly higher revving routine while getting up to plane. No other strange noises coming from the out drive that would indicate problems and boat and motor well maintained with lot's of like left in the AQ140. Cruise around at slower speeds for hours and no problems what so ever.
Could a gear system be slightly slipping somehow and then occasionally totally slip? If it sounds like a overhaul of the leg I was contemplating just buying a used 280 for $700.00 and throwing it on just to get the boat gone now and then haul apart the old 280 over the winter and sell it come Spring. Thoughts anyone?
Thanks.
Glen"
Thanks.
Glen"
