1978 tilt trim for a johnson 85txlr78
fireguy67
"my tilt trim goes up but will
"my tilt trim goes up but will only go down manually,when you press the down switch the motor makes noise and it tries to go down but seems to be labouring? Any help would be appreciated"
"no, you can hear the motor bu
"no, you can hear the motor but it sounds bogged down,it would probably take 20 min to get it down by the switch if it would even make it down,I didnt want to run to long,I tried the switch for about 40 seconds at a time with no luck"
There is more trim up than dow
There is more trim up than down pressure...i have found in the past the tilt ram upper bush is seized and needs to be freed up.
"Does the internal pump motor
"Does the internal pump motor thermal relay activate? If the motor is drawing too many amps, it will click off and resets on cooling.
If the relay is not engaging, does this give a clue?"
