ryans01z28
About a week ago I tried starting my boat and the starter wouldn't engage the flywheel so I tapped on the starter with a hammer and then it worked. I tried to start it again and same thing happened by the 3rd go around the started completely stuck wide open and I couldn't get it to shut off and some of the wires started getting really hot so I had to disconnect the battery. I then ordered a new started and a new relay. Tonight I went to try the boat with the new parts i put in and it fired up numerous times so off to the lake I went with my fixed boat. I put the boat in the water and went to fire it up and when I turned the key the started wouldn't engage the flywheel again. all it would do is free wheel without the started drive assembly contacting the flywheel! Off came the engine cover and I gave the starter a light tap and off it went. This is continuing to happen and I don't know why. Does anyone have any advice for me?
