" I have a problem with full t
" I have a problem with full throttle it doesn't want to go. I cleaned out the carbs that didn't work. I rebuit the fuel pump, took a compresion test it's fine. My gas tanks are metal and are supposed to have vents but i crack the lid at full throttle and the same thing happens slow speed. i pull the throttle up making it 3/4 and it starts to run better. When i pull the choke up 3/4 speed it gets 3200 rpms. When i put the choke down it slows down as well back to 2300 rpm. When i spray carb cleaner into the lower carb hole its picks up speed to 5000 rpms. Then when the spray stops the speed stops. I also sprayed the top carbs to see if it did the same thing but nothing happened. Also when u stick your fingers in the bottom carb it starts to speed again. Are the bottom seals bad. Are they called the lamberg seals or something like that. "
