forrest0330
Gentleman I am in need of assistance. I have two issues I need help with one is the removal of the shift lever mechanism and he other is the proper procedure to replace the gear oil in the lower unit.
First: I can completely remove all bolts and nuts to free the shift lever mechanism from the engine. But I can not remove the assembly from the gear mechanism allowing me to remove the shift mechanism from the motor. What step am I missing?
Second: I have downloaded the manual form my engine and in the maintenance section it states to remove the vent screw then the drain port screws. I can locate the drain plug easily however, I have two ports above the anti cavitation plate, One is a plastic screw and states flush, the other is approximately 2 inches to the left. which one do i remove and how do I replace the oil in the lower unit/
any help would be greatly appreciated.
