1978 Mercruiser 140 Rebuild issues
tcooke
I picked up a "rebuilt&#34
I picked up a "rebuilt" 1978 Mercruiser 140 short block. Problem is I couldn't get the crank to turn so I disassembled the block. once I loosened the main bearing caps the crank was free to turn. Once I torqued them back to specs the crank was solid again.
Whats going on here?
"incorrect bearings, mike the
"incorrect bearings, mike the crank surface, install a main bearing, torque to spec, measure the ID.
Id minus OD = clearance
mains
1-4 .001-.0024
5 .0016-.0035
rods .0017-.0027"
