MickeyShowers
Hello all,
Any help you can give me with my old Merc would be greatly appreciated.
Symptoms/Background
Last spring the motor got to where it wouldn't idle unless I had the spark advance lever at mid position. One day I put the boat in the water and it absolutely wouldn't stay running unless spark advance was up. When I put it into gear, it would act like it was going to die unless I hit the throttle. At full throttle, it would surge. I suspect this was a come and go miss on one of the cylinders.
I took it to the shop and the mechanic said that he found that the wire to the #1 ignition coil was bad. Rather than replace the whole harness, he just built a jumper. I ran the motor a couple of times last season after that and it ran better but still didn't seem right. This season, I got the boat out from storage, and it's back to the same old story. I haven't taken it to the lake because I can't get the thing to idle in the driveway. I followed the mechanic's lead, seeing the deteriorated state of the 40 year old harness and built 3 more jumpers to the other coils. No change.
Long story short, does anyone with experience with these motors recognize the symptoms? Am I in the right ballpark thinking it's ignition that's causing the problems?
What I really need is a good troubleshooting manual for this model. A buddy of mine told me that I would need a bunch of special tools to work on the ignition. Is that true?
Symptoms/Background
