Mick Stinger
To All,
I know this topic comes up allot, I have searched through the forums and have not found a solution to my problem.
The problem was noticed when my tacho stopped working and volt meter was showing that it was not charging.
I put a meter on the battery terminals whilst the motor was running and showed 12.3 volts as per the volt meter.
I had a spare regulator so I changed this out with no success, I then did a diode test on my recitfier and confirmed that the rectifier is ok.
I then did a voltage test on the output terminals on the rectifier, I was getting erractic voltage readings between 0 and up to 19.8 volts.
I did an ohm test on my stator and got the correct reading of 1.5 ohms as per the service manual.
My last test I did and ac Voltage out put on the stator, this was giving me the same results on the ac side.
Would this indicate that the stator is bad?
Thanks for any help it will be greatly appreciated.
