From the beginning, this boat sat for about 3 years. So tried reviving it. At first I had no knowledge of boats at all. I could always get it stayed but come to find out the choke wasn’t closing all the way. I didn’t find that out for about a year into it. It would be very hard to start but once it did, for the rest of the day it would start on first crank for the rest of the day. So i started trouble shooting. So far I’ve replaced, bad power pack, 4 spark plugs, all new fuel lines, new primer bulb, new battery cables, choke solenoid, starter, and more. Now, the boat is at the point where it fires up beautifully. But will not go past 15 mph. I’m sure it’s not good but I tried something yesterday, I choked the boat for about two seconds while running full throttle, and it picked up and went full speed. So I ran it for a couple minutes like that, then fished for a couple hours. Tried the same thing on the way home but it only worked for about 10 seconds then bogged back down on its own.
Compression test was
110
110
100
100
im not sure what jumping 7/16 gap means but I bought a spark tester and they all have spark.
So long story short, used to be hard to start but once it did it ran flawlessly. Now I’ve replaced a bunch of parts and it starts perfect but won’t get up to speed.
110
110
100
100
