1978 johnson 85 hp lower unit
dannyvan
"Hello, This is my first time
"Hello, This is my first time on marine engine. Hope all goes well. I need to change the impeller and i have the 4 lower bolts loose and the bottom carb. off. Not sure what is next. someone said a bolt under the carb needs turning? I looked and i'm not sure what i'm looking for? can anyone help? thanks
dan 1978 johnson 85 hp"
"u need to disc shift rod,at l
"u need to disc shift rod,at linkage under carbs...dont forget the bolt under trim tab."
