" Yesterday was the first day
" Yesterday was the first day on the water with my first boat. Thanks to Joe Reeves and everyone that helped me on this board to get the boat in shape. My apologies to everyone at the boat ramp that had to wait while I mud wrestled with my 20' pontoon to get it back on the trailer. In retrospect I should'nt have completely submerged the bunks. I'll do better next time.
The engine did not want to idle in the water. It idles fine on the garden hose and on the warm up lever (high speed). It runs fine off of idle just about where the high speed carb circuit comes into play. I need to recheck my linkage adjustment, I think the float level needs to be raised ever so slightly and next time on the water I need to check the timing. (19*@3500 rpm minimum in gear per service manual) Unless someone can tell me how to check the timing out of the water on water ears.
I haven't verified the thermostat operation or even the presence of a thermostat. The water begins flowing as soon as the engine starts and after a hour of operation the water is still cool to the touch. Should the water from the pee tube be warm or hot? Should the water begin flowing as soon as the engine is started even when cold? "
