yet another case of the famous water pump replacement, and nothing happening.
ok so here is the run down.
when i got the boat it was not peeing. i replaced the water pump assy with a kit that included everything. the housing, the pump, and all the seals ect.
the impeller that i removed had melted into the housing so clearly it was bad. i re-installed the water pick up tube, and impeller housing extension correctly(like 15 time) as to thats how many times i re-checked my work, and still nothing. i removed the cylinder head cover, and found no thermostat, but yet it shows a t-stat in the parts diagram (78 35r78r) model number. i used a garden hose, and put it where the t-stat would go and back flushed the motor. i got water out of all the right places with no issue.
soooo.
would the water pump plate need to be installed a certain way?
im using rabbit ears for a water source.
the thermostat is missing.
i did find debris out of the 90 degree overboard indicator, and removed it.
fishing season is at its peak here in alaska, and im missing out guys. any help would be great. thank you.
soooo.
