Hello, new to the forum ! I've owned a few older omc motors over the years. Used to have a 14ft Lund with a 1985 Johnson 25 on it. Switched to a riveted lowe 1648 mod V to have a little more room for hunting gear. Boat is a tiller with a 15" transom. Since I've had this boat it has had a 1973 evinrude 18, 1974 Johnson 25 and now has a 1978 Johnson 35 on it. I still have the 73 and 74 motors. I recently picked up the 35 for a little more power under heavy load while hunting. Got the motor for cheap knowing it would need some work. I put new plugs and lower unit oil in right away. The issue is that it is flooding badly and running rich. I had to adjust the throttle linkage to open the butterfly a little more at idle to even get the motor to start. I ran the motor Sunday morning on the water and it started with no choke on the second pull with a 22 degree air temperature. The motor will still idle with the slow speed needle valve back seated fully lean. The motor is hard to restart when warm. Plugs are both black. I pulled the carb apart and checked the float. It was level with the body and not leaking or punctured. I've got a carb rebuild kit on order. I'm thinking maybe the needle isnt seating properly and letting gas through all the time ? I've never seen a motor that if it doesnt start in a couple pulls needs the plugs pulled to get the liquid gas out of the cylinders. Also any recommendations on prop ? The prop on the motor is a 10.5x11 and is in poor shape from someone trying to cup it. I'm planning on replacing it with a primary goal of carrying a good load. My 1974 25hp pushes my boat around 20-22mph with 4 guys and a full hunting load with the high load prop. It takes forever to plane out. I'm not looking for miracles. Just to be able to plane out efficiently with a hunting load and get 25mph if possible. Thanks
