"I am going to rebuild the car
"I am going to rebuild the carbs on my johnson 140. I have replaced all coils, power packs, thermostats, and water pump so far and the motor is still not running consistently. It did sit for a few years so i believe the carbs could be causing the issues. Any tips or suggestions for rebuilding the carbs? Are there a lot of adjustments that need to be done when rebuilding? Also yesterday, put boat in, started right up. Shut it down for a minute and it would not start again, had to spray starter fluid in carbs in order for it to start again. Thanks"
