1978 Evinrude shaft problems and starting issues
Steaknbaked
Hello, I just purchased a boat with a
1978 Evinrude 35 hp 35853R Outboard Motor​
The guy I purchased it from said it only needed a carb clean on the motor, figures as they always say that’s the issue.
So I cleaned the carb and put in a new fuel pump.
It won’t run on a regular idle still, and if I can get it to stay running and bump it into gear it’ll jump and then shut off.
I also noticed some what looked like oil coming from the weep hole, and then I checked the gear fluid and it was milky white.
I’m thinking about getting it serviced but it sounds like a handful of problems that it’d just be cheaper to look at a newer motor.
This is my first boat so if anyone has any suggestions it’d really be a big help.
Thank you!!
P.S. I can add pictures if needed.
Could be running on just one cylinder too. That's why the outpouring of oily substance. Gearcase leak is secondary. Fishing line behind prop? I just repaired 2 motors with powerpack dead on one cylinder, it's quite common.
