Chyslerfish85
I have an 85hp chysler outboard with a 2 piece gearcase . I think it's a 1978 but couldn't verify? I'm having an issue as I pulled apart the gearcase to change the impeller, water pump gasket, water pump seal. I pulled it apart and for the life of me I can't find any of the seals or gasket that matches mine?
In my manual it shows matching pump housing and gasket but manual shows a different impeller than what was installed. Manual shows impeller with 12 fins and the impeller i pulled out had 6 fins.
Now it gets really weird when I try to find the water pump gasket and the water pump seal. I can't find the proper gasket or seal anywhere? I own a Sierra book and it shows gasket for a pump that I believe is for a 1 piece gearcase but I'm not 100%. Does not match though.. I have material to make my own but didn't want to go that route.
I am looking for the correct part numbers for the impeller, water pump gasket and water pump seal??
I have a bunch of photos and can't figure out how to post them
. Any help would be greatly appreciated.
Chysler 85hp 3 cylinder outboard
Serial # 7589
Model # 857HE
Water pump housing # 369060
Serial # 7589
Model # 857HE
