1978 85 hp johnson
kennysmith
I have a '78 85hp Johnson
I have a '78 85hp Johnson that runs fine with the ears on but not in the water. It's not missing but it seems to bog down & will go dead if i give it full throttle...what's wrong?}}
"It may sound fine on a flushe
"It may sound fine on a flushette but it is not running fine.
Check compression. What are the readings of the individual cylinders? With the spark plugs removed, the spark should jump a 7/16" gap with a strong blue lightning like flame.... a real SNAP! Does it? The 7/16" gap is important, do not waste your time checking spark by using the spark plugs!
(Spark Tester - Home Made)
(J. Reeves)
A spark tester can be made with a piece of 1x4 or 1x6, drive a few finishing nails through it, then bend the pointed ends at a right angle. You can then adjust the gap by simply twisting the nail(s). Solder a spark plug wire to one which you can connect to the spark plug boots, and a ground wire of some kind to the other to connect to the powerhead somewhere. Use small alligator clips on the other end of the wires to connect to ground and to the spark plug connector that exists inside of the rubber plug boot.
Using the above, one could easily build a spark tester whereas they could connect 2, 4, 6, or 8 cylinders all at one time. The ground nail being straight up, the others being bent, aimed at the ground nail. A typical 4 cylinder tester follows:
..........X1..........X2
.................X..(grd)
..........X3..........X4
Thousands of parts in my remaining stock. Not able to list them all. Let me know what you need and I'll look it up for you. Visit my eBay store at:
http://stores.ebay.com/Evinrude-Johnson-Outboard-Parts-etc?refid=store
S/Plugs should be Champion QL77JC4 plugs, gapped at .040 . If the above areas are as they should be, in all probability, the carburetors are fouled and need cleaning and rebuilding.
