1978 80 hp Main Harness Connection
The pins align it.There may be a spring clamp on the control side of the connection,but it shouldn't be that difficult to separate them,I'm assuming that the engine harness and control harness are connected,they should pull apart.Unless there is corrosion inside the pins.
I saw the spring and didn't think it as a clamp. I'll go out and work on it some more. BTW, I have less clues then you do.:confused:
Thank you again for the reply.
Carl
