Jonathon123
Hi all. I am hoping someone out there can help me.
I am fixing a 78 50 Horse Merc. 4 cyl.
The problem started last yearon the water. Motor would run for a few seconds then die instantly only way to keep it running was to pump fuel in via fuel line. Ignition spark is strong on all plugs, compression is 120-125 on all 4 cylinders. I removed carbs and the bowls were full of fuel, floats appear in good shape, needle valves appear to be working and moving, I cleaned the carbs completely and replaced fuel pump diaphragms. Now when i start it it runs at high speed only and is very difficult to start. Once i finally get it running it will only run at 1/2 to 3/4 throttle As soon as i back off the throttle the motor will die.
I am hoping its not crank pressure issues...
thoughts anyone???
thoughts anyone???
