hey guys, after owning a 1976 25hp rude pullstart for years, i finally decided to (upgrade) to a 1978 35 hp elec. start motor. i absolutley love the motor, it runs, idles, starts, etc. with perfection, (i love these older motors) anyway,.....my question is this: i have two batteries on the boat, one for trolling motor, and one (brand spanking new) marine battery just for engine starting. now, every now and then i will run the trolling motor battery*dry, and use the starting battery for a little longer fishing time, and if that one goes dead then i can simply use the old reliable pullstart on the motor to get me home. again,.......to the point,.......should my motor re-charge the battery like a vehichle with an alternator??because most times when i take it out, i only use the starting battery to run the motor, and even after a full day of fishing (and a 40 minute ride back to the boat ramp) which i would think would be enough time to recharge the battery after only one crank for about 3-5 seconds, it still only shows 70-80% battery life when hooked back up to the charger. and keep in mind this is when i havnt used that battery for anything else but engine starting. i can only assume the power pack, magneto, alternator, or whatever it is called is working, because it will run on pullstart even without a battery. im sorry, i know im long winded, just wanted to give you the full spectrum!!!! any advice or knowledge of the issue would be appreciated!!!!!
thanks!!
thanks!!
