fishinhard
"Hi all, ok here is what I am
"Hi all, ok here is what I am dealing with. 1978 with a GM staight 6 250 ci. New plugs wires, cap, rotor, and plugs. Rebuilt the carb and it starts up no problem. The problem is when I come off of idle it wants to spudder. I can back of just a touch and it will rev right up. I messed with the timing thinking that might help. I did some but now it has a slight miss. At idle and higher. I took it out this weekend and that is when I could feel and hear a cyc not working right. I has the electronic converson in it. Is there a way to check the air gap and if so what should it be. My next thought is if the valves are not adjusted properly will that cause this problem as well. It has a newer fuel pump, brand new fuel water sep as well. When I got the boat a few months ago it did not even run. I was running pretty good till I took it out. The spudder off of idle has been there since I rebuilt the carb. Any sugestion would be great."
