aquaholictom
Engine will not start unless I use starter fluid in each of the 3 carbs. When it starts it runs good.
The other day I was out and after getting it started with the starter fluid. It ran well most of the day until I started it back up and it would only run very slow. I stopped the engine and then couldn't get it started again. Fuel was going to the carbs and there is fuel when I open the plug at the bottom of each carbs.
It sounds like I need to rebuild the carbs. The motor has been sitting for more then a year before I bought it. Any opinions out there?
