I have a 1978 115 hp Johnson outboard that is leaking red fluid (oil). It appears to be coming from the power head / engine and runs down the midsection. I can't identify a specific location where the fluid leaks.
The fluid is the same color as the two stroke oil I use, and smells like gasoline. It appears that there is more fluid when I run the motor connected to a hose / motor flusher, but after a day on the water there is very little fluid.
Aside from this leak, the motor runs great...starts and idles well, and still pushes an 18' fiberglass boat at 32mph.
Is it two stroke oil? Why is it there? How serious is this problem?
